SR 3D Builder 0.7.3.12 just released
xSergio74
Mensagem por xSergio74 » 20 ago 2012, 15:39
Another updated version of the application is now available from http://sr3dbuilder.altervista.org/
Most significant new feature is STICKER support as shown in this video:
Following is a list of what is changed.
Enjoy Building !!
Sergio
0.7.3.12 - Changes to previous version (2012.08.20)
Fixed
- Parts selection can cause application crash when using groups
- Problems aligning parts along a vertical axle
- Animation of Linear Actuators was a bit incorrect
- Animation of some kind of complex hinges was incorrect (not totally fixed but anyway better than before)
- Flex parts management should now work again !!
- When rotating the viewpoint with RMB can accidentally (but very annoying) add your selection to model
  when releasing button over yellow and blue center
Added
- Support for STICKERS!! ( for registered users ). Please notice that since stickers connections are added
  on-the-fly to model parts, this causes the following different behaviors in the UI:
    . The sticker follow mouse pointer over bricks it can connect with (and auto-orient according to part
      surface slope)
    . You can only use the keyboard to rotate a sticker and add it to the model (use <SPACE> or <ENTER>)
- Application now creates a backup of your model before saving it
- Latest lDraw official parts update (August 2012)
