LEGO Powered Up App 3.0
I'm happy to share the following update from the Powered Up team:
Ready for an early Christmas present? We are super exited to reach this milestone in our digital system in play, with LEGO Powered Up 3.0. With this update we hope to further empower your creativity and enable all of you to rebuild the world. Also, we have a fresh new look!
What’s new?
· For those of you that have more than one hub, good news, you are now able to connect, address, code, and control multiple hubs (up to four actually).
· The app now fully supports the new LEGO TECHNIC hardware. You are now able to connect the new LEGO TECHNIC hub, and use the internal tilt sensor, as well as the new LEGO TECHNIC motors. For the real techy ones, the app can read values from internal sensors (orientation (X, Y, Z), and acceleration (X, Y, Z) of the TECHNIC Medium Hub (Hub128). From the app you can pair motors on port AB, and CD. The app also supports the TECHNIC Large Linear Motor (Motor no. 2) and TECHNIC XL Linear Motor (Motor no. 3). From the app you can regulate power, speed and position of motors.
· Last but not least, the app has gotten a makeover! We’ve given the interior of the two lobbies a thorough clean-up and made it easier for you to create new projects. We’ve also cleaned up the canvas a bit, and don’t worry, all of your canvas features are still available in the little menu in the bottom right corner.
Feedback wanted
This is just the beginning. With this update comes a promise and commitment to keep improving and listening to your feedback. If it’s not too much to ask, please help us become even better by sharing your ideas for improvements, and your awesome creations with the LEGO Powered Up app.
We will be collecting your questions posted in this thread and deliver them back to the technical hardware team in January 22nd 2020. Any answers we have will then be posted here.
É um prazer partilhar a seguinte actualização da equipa Powered Up:
Prontos para um presente de Natal antecipado? Estamos super empolgados por alcançar este marco no nosso sistema digital em jogo, com o LEGO Powered Up 3.0. Com esta actualização, esperamos fortalecer ainda mais a vossa criatividade e permitir que todos vocês reconstruam o mundo. Além disso, temos um novo visual!
O que há de novo?
· Para aqueles de vós que têm mais de um hub, boas notícias, agora podem conectar, endereçar, codificar e controlar vários hubs (até quatro actualmente).
· A aplicação agora suporta totalmente o novo hardware LEGO TECHNIC. Agora podem conectar o novo hub LEGO TECHNIC e usar o sensor de inclinação interno, bem como os novos motores LEGO TECHNIC. Para os realmente técnicos, a aplicação pode ler valores de sensores internos (orientação (X, Y, Z) e aceleração (X, Y, Z) do TECHNIC Medium Hub (Hub128). A partir da aplicação, podem emparelhar motores nas portas AB e CD. A aplicação também suporta o TECHNIC Large Linear Motor (Motor nº 2) e o TECHNIC XL Linear Motor (Motor nº 3). A partir da aplicação, podem regular a potência, a velocidade e a posição dos motores.
· Por último, mas não menos importante, a aplicação passou por uma renovação! Demos uma limpeza completa ao interior dos dois lobbies e facilitámos a criação de novos projectos. Também limpámos um pouco o ambiente de trabalho e não se preocupem, todos os seus recursos do ambiente de trabalho ainda estão disponíveis no pequeno menu no canto inferior direito.
Feedback procura-se
Isto é apenas o começo. Com esta actualização vem uma promessa e compromisso de continuar a melhorar e ouvir os vossos comentários. Se não for pedir muito, ajudem-nos a melhorar ainda mais, partilhando as vossas ideias de melhorias, e as vossas criações incríveis com a aplicação LEGO Powered Up.
Reuniremos as vossas perguntas colocadas neste tópico e as enviaremos de volta à equipa técnica de hardware em 22 de Janeiro de 2020. Quaisquer respostas que tivermos serão colocadas aqui.
What’s new?
Feedback wanted
O que há de novo?
Feedback procura-se
Re: LEGO Powered Up App 3.0
A aplicação Powered Up não é das mais fáceis de se usar, pois tem montes de blocos de programa e nenhuma documentação para eles.
Para mitigar isto, foram publicadas no RacingBrick duas tabelas que explicam o que fazem os blocos e como se usam.
Lista simplificada: https://racingbrick.com/powered-up-code-block-guide/
Lista estendida: https://racingbrick.com/powered-up-code ... uide-full/
- AGarcia
- Administrator
Muito útil!
Obrigado
Obrigado
A equipa Powered Up partilhou uma carta aberta aos fãs, em que explicam a situação actual da aplicação, das suas funcionalidades obtusas de utilizar e da sua documentação:
- CyberX
não só não explicam nada como fazem uma afirmação que deve ter arrepiado todos os engenheiros lá dentro: prometem assegurar a conectividade de todos os sistemas LEGO actuais e passados! Se nem todos os AFOL geeks do mundo o conseguiram ia lá ser a LEGO
Pois, no fórum da LAN falaram em usar o PUp para controlar comboios de 12V.
- CyberX
isso é fácil... agora metam é o PUp a controlar o Interface A
(porque o B estamos lá quase, pelo menos no papel)
Entrevista do RacingBrick ao product owner da aplicação Powered Up!
Texto aqui:
https://racingbrick.com/2020/05/lego-po ... -intervew/
Vídeo aqui:
Texto aqui:
Vídeo aqui:
