Os nuestro hermanos da Hispalug, tb estão a organizar perguntas que periódicamente enviam à LEGO, num esquema em tudo idêntico.
Agora publicaram os resultados da primeira leva.
Podem ver as perguntas e respostas, aqui.
Perguntas e respostas da Hispalug
Re: Perguntas e respostas da Hispalug
Boaboaboa! Um receptor PF novo! Quem sabe se terá os 8 canais?Does the "single pin error" affect the way the new PF lights (LEDs) can be actuated and will TLC change already bought IR receivers for fully functional ones once these are available?
This does not affect the way PF lights will work with the RC Receiver.
Since this is an extra function of the RC receiver it will be treated as an upgrade when we release the next version.
jetro
- Full Member
Unfortunately it also means that the existing IR-receivers we already have will not be substituted for others with full funcionality
