Ask a designer
Ask a designer
Não que não tivessemos já a confirmação da resposta através do Jan (pergunta e resposta 4, aqui), contudo parece que foi a vez de uma das minhas  perguntas ter saído na tombola. ;)
http://technic.lego.com/en-US/designstu ... fault.aspx
Neste momento está no topo, mas em breve deixará de está, portanto aqui fica a sua transcrição,
"Which was the LEGO goal by designing the upcoming TECHNIC Linear Actuator, that we see for example in the new Excavator (8294)? Develop a new part, to add functionality and new possibilities or does it aim to replace the Pneumatic Cylinders role in TECHNIC sets?
- FCorreia
The goal we set for the new linear Actuator was to be able to add new functions and possibilities together with the new Power Functions system. On top of that we also designed it so it can be used to add functions in models that do not include motors. It is not the idea that it should replace any of the pneumatic cylinders :-)
