Novo 'Mini Motor' para linhas Technic e Mindstorms
já reparam neste 'Mini Motor' feito para LEGO Technic e Mindstorms, com peças LEGO originais?  8)
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... &rd=1&rd=1
Edit: Novo item em http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... &rd=1&rd=1
Após terminar cada leilão, é adicionado um novo.
Vejam-no em acção, no YouTube:
http://www.youtube.com/watch?v=GaKb13EMe9I
É feito por 'absimple' (Mauricio Cuartas) nos EUA e vendido apenas no eBay. Já comprei alguns e parece-me muito bem conseguido  :)
Permite um modo de fixação muito útil na linha Technic/Mindstorms :D
- NEW mini size motor
- Reversible direction (forward and backward)
- 360 RPM at 9 volts (variable speed if used with different voltage)
- Internally geared down for a great combination of speed + power
- Chassis design allows compact and strong connection with other Lego pieces
- The Mini is actually stronger than the standard size motor
- Pulley/Bush terminal have a "clutch" mechanism that protects the motor when your creation gets stuck
- This Motor remains "locked" when turned off meaning that if for example you use it to build a crane, it will support the weight in mid air once you turn it off
- The Mini feature "brake" stop for precise control.  When you turn it off the Mini Motor stops immediately
*NXT Robot users:  You will be able to program this motor to change speed, direction and to set the time it runs.  The Lego Converter Cable is needed (Offered by us, check 'seller other items' or at Lego Store Online, Item #8528).  Please note that this motor is assembled inside genuine Lego bricks allowing full compatibility with Lego Technic, Mindstorm and NXT sets.  This motor is not made by Lego but it works as good as any Lego motor in fact Lego does not build motors, other companies do and Lego put them inside their bricks (as we do)
Última edição por Conchas em 12 fev 2007, 01:55, editado 1 vez no total.
Re: Novo 'Mini Motor' para linhas Technic e Mindstorms
Mensagem por Ricardo T »
Que interessante! Obrigado pela dica!  8)
Notas que tenha a mesma força que o da LEGO? E quanto ao peso? As vezes dá jeito um motor desses mais leve!
Efectivamente acho o motor bastante forte e leve.
Já sei que no futuro vão saír versões em novas cores. Por exemplo com o corpo transparente  8)
