SR 3D Builder version 0.8.3.18
xSergio74
Mensagem por xSergio74 »
Here I'm to announce the latest new release of my application.
Official web site: http://sr3dbuilder.altervista.org/
It takes by far much longer than what I expect, but it worth the waiting!!
Here is a pair of videos to show what I'm talking about:
A lot of fixes and some major addiction are available. Here is a list of changes.
Please read carefully for what pneumatic parts are currently supported. More to come...
Fixes
- Drawbrickmode: Slope parts are only partially displayed
- Extra unuseful connection added to Axleholes
- Picking a brick can cause wrong group assignment
- A lot of Pneumatic parts fixed and technic parts cleanup
- Some unwanted parts keep sliding in animation
- Pin with bush was incorrectly managed causing wasting time in animation computation
- The ClearConsole button has no way to cancel the operation
- The Bump Mode option in Animation Console was not saved in model
- Application crashes when loading a model if it has a switch ring (part 6539) not connected to an control handle used in AnimationConsole
- Restoring group view in big models can cause crash when hovering with mouse over model
- Starting an animation AnimationConsole without starting a classic animation before causes nothing to happen or application crash
- Locked Block in Animation Console was not correctly loaded from a saved model
- In animation, all parallel translation keep moving together
- Resetting animations does not reset flexible parts
- If you try to save model in the application folder you can fall into an infinite loop
- Towbar steering has a little wrong movement when used with shock absorber
- Towbar steering could hanging when mixing steer and shock absorber
- Sloped shock absorber were not having correct slide length
Added
- Major addiction: management of some pneumatic parts
    . flexible tubes and air splitters
    . switches (input from central and exit from lateral connections only)
    . small, medium and big pump (not connected to motor)
    . small pistons only
    Pistons speed is still not correctly managed. Be patient...
- Hinge solve now can connect pneumatic pistons
- A marker showing where DrawBrickMode starts
- Alt + mouse wheel moves selection a whole brick up/down (24 instead of 8)
- Latest lDraw official update has been included
- Many technic parts addiction to Mirror List
Changes
- to easily connect a piston to engine cylinder do the following:
    Enable Alternative UI (by pressing <U> key)
    align piston to cylinder moving mouse and holding LMB pressed and then release it
    correct orientation by pressing keys (you cannot click the pivot arrows while in UI) to rotate piston (don't mind if piston will move following your cursor)
    hoove to the ball over the rod to connect the piston
    Easyer to do than to explain. Try it!
Re: SR 3D Builder version 0.8.3.18
Really amazing at each new step Sergio, as you have already used us! :fixe:
Thebicyclestory
I have just downloaded the new version.
Great work Sergio, many thanks! :fixe:
I have a problem thought:
Everytime I double click on a part, an error pops up saying:
"Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Index was outside the bounds of the array."
Filipe
Última edição por Thebicyclestory em 11 fev 2013, 12:27, editado 1 vez no total.
DARK AGE or maybe just busy?
xSergio74
[quote="Thebicyclestory"]
Filipe
Hi,
to try to solve the problem, do the following
- Reinstall the software.
- During install take notice of the folder where the part library is going to be installed.
- At first application run, use the Menu.File.Setup Directory functionality to specify the noticed folder
- Use the Tools.Rebuild Part List functionality to rebuild part list index (may take a pair of minutes. It is not hanging, just wait...)
- Close and restart the application
- Check if it is working and feedback...
Sergio
