76052 - Batman™ Classic TV Series – Batcave
Idade: 14+
Peças: 2526
Preço (DE): 249.99€
Disponibilidade: a partir de Março de 2016, em http://shop.LEGO.com, Lojas LEGO® ou via telefone
Peço desculpa por estar em inglês, mas o texto é demasiado longo para estar a traduzir tudo à mão...
Drive the villains out from Batman’s Batcave!
Help Batman™ and Robin™ to drive the villain intruders from the Batcave, featuring a Bat Lab with Batcomputer, plus the Batmobile with stud shooters, Batcopter with flick missiles and the Batcycle. This special model, based on the classic 1960s TV show, also has a Wayne Manor section with an exterior wall to climb on and Bruce Wayne’s study featuring the iconic Batphone and a false bookcase that slides open to reveal the secret entrance to the Batcave. Before spiraling down the Batpoles into the Batcave, change identity from Bruce Wayne™ and Dick Grayson™ into Batman and Robin (separate minifigures included).
• Includes 9 minifigures: Batman™, Robin™, Bruce Wayne™, Dick Grayson™, Alfred Pennyworth™, The Joker™, Catwoman™, The Riddler™ and The Penguin™.
• This LEGO® model of the Batcave as seen in the classic 1960s TV series features 2 Batpoles for Batman™ and Robin™ to slide down, a selection of Bat-gadgets, helipad, plus a Batmobile and Batcopter.
• The Wayne Manor section of the model features Bruce Wayne’s study with the iconic Batphone, a hinged Shakespeare bust with secret button underneath, sliding false bookcase to access the Batpoles, and assorted elements including decorated wallpaper bricks, wall lamps, framed portraits, a framed fish and trophies. It also includes an exterior wall for climbing, with an opening roof for easy access to the Batpoles and an aerial element.
• The Batcave incorporates a hi-tech, 2-floor Bat Lab with Batcomputer element and a variety of detachable accessory elements, including a lie detector machine, table, chest of drawers, Bat-gadgets and test tubes with translucent elements. Also includes the iconic Batcave entrance for the Batmobile and a helipad for the Batcopter.
• The Batmobile features a dual cockpit with iconic Batphone, 2 stud shooters, an opening trunk, dual exhaust and sign stickers.
• The Batcopter has an opening cockpit for a minifigure, bat-inspired wings with 2 flick missiles, spinning rotors and a spinning propeller. A villain minifigure can grab onto the back of the Batcopter for more aerial battle action.
• The Batcycle features a driver’s seat for Batman™, translucent headlight element and a sidecar for Robin™.
• Also includes a cat.
• Weapons include The Joker’s TNT, Catwoman’s whip, The Riddler’s TNT and The Penguin’s umbrella.
• Accessory elements include Batman’s 3 Batarangs, rope, grappling hook and handcuffs.
• Includes separate minifigures for Batman™ and Robin’s alter-egos, so enter the secret doorway as Bruce and Dick, and slide down the Batpoles as LEGO® DC Super Heroes!
• Batcave measures over 18” (46cm) high, 22” (56cm) wide and 7” (20cm) deep.
• Batmobile measures over 2” (6cm) high, 8” (21cm) long and 2” (7cm) wide.
• Batcopter measures over 2” (7cm) high, 8” (22cm) long and 7” (19cm) wide.
• Batcycle measures over 1” (4cm) high, 3” (8cm) long and 1” (4cm) wide.
Mais imagens:
Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem
Re: 76052 - Batman™ Classic TV Series – Batcave
Estava mais à espera de uma "gruta" do que uma "cave"...
ao menos o side-car é fixe.
Cool!!
Ainda bem que o meu puto de 3 anos ainda não sabe ler... Senão lá me ia melgar com a caverna do batman  :whistle:
Só 250? Pensei que ia ser mais. Muito fixe o set  :fixe:
O Video:
Eu vou querer esta peça!!!
licinionunes
Mensagem por licinionunes »
DEFINITIVAMENTE MAIS UM SET PARA A MINHA COLECAO
spacemarine
Mensagem por spacemarine »
GANDA Set :fixe:
Será que estou a ver ali umas peçinhas em Sand Red  :o
Última edição por spacemarine em 13 jan 2016, 01:14, editado 1 vez no total.
Mensagem por agadoijo »
Acho que sou o único aqui mas... não gosto mesmo nada deste set!!
Para um set de 259.99€ (sh@p pt) parece-me inacabado. Acho aquela parede de studs simplesmente feia, aqueles autocolantes no helipad (8x16) vão ser um terror para acertar, as várias partes não parecem ter qualquer ligação, tem elementos que é suposto ficarem simplesmente perdidos no meio do cenário? Como os computadores?! Para mim parece que agarraram em vários sets e juntaram tudo num para justificar o preço. Vejo perfeitamente o batmobile como um set separado um pouco à semelhança dos ghostbusters.
Pelo preço isto é um set apontado para adultos, os adultos gostam de ter os sets montados em display... algo que fique bem na prateleira... isto... não fica... o design parece apontado para crianças com todas as playfeatures.
Eu sei que os sets licenciados são mais caros para pagar a licença... mas olhem para o número de peças (2526)... olhem para outros sets licenciados, olhem para a casa dos simpsons (2523) por 199.99€!
Não és o único.
Acho caro e não gosto nada da linha "anos 60". Só gosto mesmo do side-car e da ideia dos azulejos, pode ser que um dia venha a haver azulejos azuis e brancos para os MOCs de azulejaria tipicamente portuguesa.
E mantenho que aquilo não se parece com gruta nenhuma. É verdade que no inglês "bat-cave" tanto possa ser "gruta" como "cave" (como em aquilo que fica por baixo do rés-do-chão e acima da sub-cave) mas parece mais umas ruínas ou umas obras.
Mais sets da trilogia do Nolan é que era  :fixe:
Realmente, um Tumbler com direcção e suspensão seria provavelmente fazível.
amcarmo
Mensagem por amcarmo »
Um set que terá mesmo de vir para a minha colecção DC
Ainda se vendessem o Batmobile em separado... Assim, fico muito feliz porque vou poupar 260 euritos.  ;D
