10256 - Taj Mahal
10256 - Taj Mahal
Idade: 16+
Peças: 5923
Preço (DE): 329.99€
Disponibilidade: a partir de 27 de Novembro de 2017, em http://shop.LEGO.com, Lojas LEGO® ou via telefone: 00-800-5346-1111
Peço desculpa por estar em inglês, mas o texto é demasiado longo para estar a traduzir tudo à mão...
Discover the architectural wonder of the Taj Mahal!
Build and discover the Taj Mahal! The huge ivory-white marble mausoleum, renowned as one of the world’s architectural wonders, was commissioned in 1631 by the Emperor Shah Jahan in memory of his wife, the Empress Mumtaz Mahal. This relaunched 2008 LEGO® Creator Expert interpretation features the structure’s 4 facades with sweeping arches, balconies and arched windows. The central dome, subsidiary domed chambers and surrounding minarets are topped with decorative finials, and the raised platform is lined with recessed arches. The model is finished with ornate detailing throughout and intricate tilework around the base. With more than 5,900 pieces, this set is designed to deliver a rewarding building experience and makes a great display piece for the home or office.
• LEGO® interpretation of the real-world architectural wonder, the Taj Mahal.
• Relaunched 2008 model, featuring 4 facades with arches and arched windows; central dome, 4 subsidiary domed chambers and 4 minarets, all topped with decorative finials; raised platform lined with recessed arches; ornate detailing throughout; and intricate tilework around the base.
• Divides into 7 modular sections for easier transportation.
• Put your LEGO® building skills to the test with one of the largest LEGO models ever created!
• Special elements include 6 blue 16x32 baseplates, white 1x5x4 bricks with bow, lots of transparent elements, ‘Erling’ bricks and ‘jumper’ plates.
• Measures over 16” (43cm) high, 20” (51cm) wide and 20” (51cm) deep.
Mais imagens:
[align=center]Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem Imagem[/align]
"Designer Video":
[align=center][/align]
Re: 10256 - Taj Mahal
Puuuum Porta aviões ao fundo...
Muito especulador agora tem que as comer com pão. É bem Lego.
ciria
Mensagem por ciria »
[quote="Nuno Lino"]
epa que guardem o set e vendam por mais 30-50% é uma cena, tiveram o dinheiro empatado etc... agora valorizações de 1000%... agora têm um pisa papeis
[quote="Nuno Lino"]
Falcon. Taj Mahal. Eu já disse - Café Corner e Green Grocer e eles até se atiram da ponte.  ;D
[quote="Nuno Lino"]
Era vê-los cair que nem tordos  >:D
Deste set lembro-me de alguém ter dito que o comprou para peças...
Não foste tu [member=163]Jollyroger[/member] ?
Jollyroger
Mensagem por Jollyroger »
[quote="AlexandreRibeiro"]
Isso é totalmente falso!! Na verdade, fui eu e o [member=956]AGarcia[/member]...
Este lançamento faz-me sentir menos culpado
[quote="Jollyroger"]
É verdade!  ;D ;D ;D
Mensagem por agadoijo »
Enquanto AFOL vejo esta medida da LEGO com bons olhos, de uma só vez acabam com o mercado dos clones e dos especuladores!
Venha de lá esse Café Corner e Green Groccer com interiores, sff!
Mas pensando um bocado sobre o assunto não sei se será a melhor ideia para a LEGO... passo a explicar, veja-se o exemplo da nova Millennium Falcon que vendeu tudo o que havia para vender e mais outras tantas caso a LEGO as tivesse feito! Agora quantas dessas Falcons é que foram efectivamente compradas por AFOLS? Quantas é que ainda estão guardadinhas a sete chaves na sua caixa à espera de providenciar um lucro de 1000%? Se não existirem especuladores penso que há uma grande parte de sets destinados a AFOLS que irá ficar por vender...
Claro que isto também é especulação da minha parte :)
ciria
[quote="agadoijo"]
Concordo contigo, a LEGO tem aqui uma faca de dois gumes. Se cada AFOL compra 2 sets, um para si outro para comercializar no futuro, estamos a falar no dobro das vendas nesse segmento. É um assunto delicado para eles. E por outro lado se eu já tivesse a falcon anterior nao ia comprar esta, as reedições a acontecerem são em sets muito específicos porque caso contrário vai saturar o mercado.
