4000026 - Tree of Creativity
In the midst of LEGO House stands one of the world’s most iconic LEGO models, at over 15m tall and packed full of details and surprises even the most avid LEGO enthusiast cannot fail to be impressed by the Tree of Creativity. The tree is constructed from 6.316.611 standard LEGO bricks and took 23.500 hours to assemble to create an incredible and unique LEGO model.
And now a LEGO small scale model of this tree will be exclusively available at the LEGO Store in LEGO House, Billund.
The LEGO model is a great reproduction of the giant tree. All the most iconic features have been resized into this retail model.
The real LEGO enthusiast will know that the LEGO Group launched a Tree of Creativity model back in May 2017. That particular model was developed as the surprise gift for the participants of the LEGO Inside Tour. The product developed for Inside Tour only comes out in 175 individually numbered boxes.
Senior designer Steen Sig Andersen who originally also designed the first model was asked to do a retail version for LEGO House.
Steen Sig Andersen says:” The former Tree of Creativity box has proven to be an iconic model for the LEGO House and it makes a lot of sense to also offer a Tree of Creativity to the guests of LEGO House. But it was very important that the two models were not identical as we would not take away the originality from the Inside Tour guests in 2017”
Steen Sig Andersen’s efforts resulted in a very nice retail version which is slightly smaller than the LEGO Inside Tour model. The model is exclusively available at LEGO House in Billund and the retail price is 599 DKK. The LEGO Inside Tour model is not for sale.
A detailed comparison between the LEGO Inside Tour set and the retail version The Tree of Creativity below.
LEGO House is a fantastic experience center, so amazing that it is hard to describe. It is a place where LEGO fans of all ages will discover the magic behind the brand and can be inspired by all the endless play and learning possibilities with the LEGO brick.
Facts about the large Tree of Creativity
    Height: 15,68 m
    Number of bricks: 6.316.611 Bricks
    Total weight (excluding metal structure): 11.053 kg incl. 600 kg of loose bricks for grass
    Production hours: 24.350
No meio da LEGO House está um dos modelos LEGO mais emblemáticos do mundo, com mais de 15 metros de altura e cheio de detalhes e surpresas, mesmo o mais ávido entusiasta LEGO não pode deixar de se impressionar com a Árvore da Criatividade. A árvore é construída a partir de 6.316.611 tijolos standard LEGO e levou 23.500 horas para montar para criar um modelo LEGO incrível e único.
E agora, um modelo LEGO de pequena escala desta árvore estará disponível exclusivamente na LEGO Store na LEGO House em Billund.
O modelo LEGO é uma óptima reprodução da árvore gigante. Todos os detalhes mais icónicos foram redimensionados para este modelo de retalho.
O verdadeiro entusiasta de LEGO saberá que o Grupo LEGO lançou um modelo de Árvore de Criatividade em Maio de 2017. Este modelo em particular foi desenvolvido como o presente de surpresa para os participantes do LEGO Inside Tour. O produto desenvolvido para o Inside Tour só vem em 175 caixas numeradas individualmente.
O Senior Designer Steen Sig Andersen, que originalmente também projectou o primeiro modelo, foi convidado a fazer uma versão de retalho para a LEGO House.
Steen Sig Andersen diz: "A antiga caixa da Árvore da Criatividade provou ser um modelo icónico para a LEGO House e faz muito sentido também oferecer uma Árvore de Criatividade aos convidados da LEGO House. Mas era muito importante que os dois modelos não fossem idênticos, pois não tiramos a originalidade aos visitantes da Inside Tour em 2017"
Os esforços de Steen Sig Andersen resultaram numa versão de retalho muito agradável, que é ligeiramente menor do que o modelo da LEGO Inside Tour. O modelo está disponível exclusivamente na LEGO House em Billund e o preço de venda é de 599 DKK. O modelo LEGO Inside Tour não está à venda.
Uma comparação detalhada entre o conjunto da LEGO Inside Tour e a versão comercial da The Tree of Creativity abaixo.
A LEGO House é um centro de experiências fantástico, tão incrível que é difícil de descrever. É um lugar onde os fãs de LEGO de todas as idades irão descobrir a magia por trás da marca e podem ser inspirados por todas as possibilidades infinitas de brincadeira e aprendizagem com o tijolo LEGO.
Factos sobre a grande Árvore da Criatividade
Altura: 15,68 m
Número de tijolos: 6.316.611 Tijolos
Peso total (excluindo estrutura metálica): 11.053 kg incl. 600 kg de tijolos soltos para relva
Horas de produção: 24.350
LITRetail product
NameLEGO® House Tree of CreativityLEGO® House Tree of Creativity
Product number40000244000026
Amount of boxes produces17510
Piece count1008837
Release date1st of May 20171st of March 2018
Box sizeLength: 310 mmLength: 382 mm
Width: 230 mmWidth: 262 mm
Depth: 72 mmDepth: 70,5 mm
PackagingCustimized sleeves – five different onesStandard retail packaging
Hight of built model38 cm35 cm
Number of leaves1110
Number of minifigures6 + baby1
Uniquely decorated elementPrinted tile with space logo0
Amount of mini builts on leaves86
Base frameWhite with integrated benchBrown without bench
LEGO DesignerSteen Sig AndersenSteen Sig Andersen
Available for saleNoYes – exclusively in LEGO House
PriceNot for sale599 DKK
Fonte: LAN Blog
