Uma mensagem da Equipa Powered Up
A message from Gaute Munch, Director Product Technology (Product owner of Powered UP)
For the past two years we have been in dialog with Ambassadors here on the LAN about Powered Up. The feedback that you have shared has been greatly appreciated. It has been insightful but also pleasure to work and brainstorm with different AFOLs around the world on Powered Up. If you are a member of a Recognized Community, thank you.
Today, we are excited to share the news below with you. We are even more excited to know what your plans are? Are there existing sets you are already excited to modify? Are these going straight into your MOCs? It is almost time for show-and-tell!
Great News on Powered Up Components!
Until now our LEGO® Technic™ Powered Up components have only been available to buy as part of the sets and we know that some of you have been interested in having the electronic components available to be sold separately.
Powered Up components are the hubs, motors, lights, sensors and control handsets that can help builders bring their LEGO models to life. The components can be used to add motorized movement and light features to models, and control them through the Powered UP App.
And now to the great news! As of 1st June 2020, fans will be able to buy the LEGO® Technic™ Powered Up components individually at LEGO.com.
The new components available individually will be:
LEGO® POWERED UP TECHNIC™ HUB (88012)
4 input/output ports for connection with LEGO® Powered Up motors, lights and sensors.
Integrated movement sensor.
Connects via Bluetooth to the LEGO® Powered Up app and the Control handset
Designed for use with LEGO® Technic™ elements.
Requires 6x AA batteries (not included).
Age mark 8+
LEGO® POWERED UP TECHNIC™ Large Motor (88013)
Use this motor for power and accuracy.
Integrated rotation sensor and absolute positioning for accurate speed and position control.
32 cm connection wire for Powered Up Hubs.
Requires a Powered Up Hub (sold separately).
Age mark 6+
LEGO® POWERED UP TECHNIC™ XL Motor (88014)
Use this motor for maximum power and accuracy.
Age mark 6+
The components will also be added to our Powered Up Components Webpage, where you will find inspiration and ideas on how to use them.
Uma mensagem de Gaute Munch, Director Product Technology (proprietário do produto Powered UP)
Nos últimos dois anos, estivemos em diálogo com os Embaixadores aqui na LAN sobre o Powered Up. O feedback que vocês partilharam foi muito apreciado. Foi esclarecedor, mas também um prazer, trabalhar e debater com diferentes AFOLs em todo o mundo sobre o Powered Up. Se tu fores membro de uma Comunidade Reconhecida, obrigado.
Hoje, temos o prazer de partilhar as notícias abaixo convosco. Estamos ainda mais excitados em saber quais são os vossos planos? Existem sets existentes que você anseiam por modificar? Eles estão a ir directo para os vossos MOCs? Está quase na hora de mostrar e contar!
Boas notícias sobre componentes Powered Up!
Até agora, os nossos componentes LEGO® Technic ™ Powered Up só estavam disponíveis para compra como parte dos sets e sabemos que alguns de vocês estavam interessados em ter os componentes electrónicos disponíveis para serem vendidos separadamente.
Os componentes Powered Up são os hubs, motores, luzes, sensores e dispositivos de controlo que podem ajudar os construtores a dar vida aos seus modelos LEGO. Os componentes podem ser usados para adicionar movimento motorizado e funções de luz aos modelos e controlá-los através da Aplicação Powered UP.
E agora as boas notícias! A partir de 1 de Junho de 2020, os fãs poderão comprar os componentes LEGO® Technic ™ Powered Up individualmente em LEGO.com.
Os novos componentes disponíveis individualmente serão:
4 portas de entrada / saída para conexão com motores, luzes e sensores LEGO® Powered Up.
Sensor de movimento integrado.
Conecta-se via Bluetooth à aplicação LEGO® Powered Up e ao controlo remoto
Desenhado para uso com elementos LEGO® Technic ™.
Requer 6 pilhas AA (não incluídas).
Idade recomendada 8+
Usa este motor para potência e precisão.
Sensor de rotação integrado e posicionamento absoluto para controlo preciso de velocidade e posição.
Fio de conexão de 32 cm para hubs Powered Up.
Requer um hub Powered Up (vendido separadamente).
Idade recomendada 6+
Usa este motor para obter potência e precisão máximas.
Os componentes também serão adicionados à nossa Webpage de Componentes Powered Up, onde encontrarás inspiração e ideias sobre como os usar.
Re: Uma mensagem da Equipa Powered Up
Penso que sejam boas notícias!
Mesmo com estes avanços todos em tecnologia continuo a achar que os melhores connectors de todos até ao momento foram da altura dos 90s.
Equivalia a duas plates 2x2 sobrepostas!
Os melhores conectores de todos foram os de 4.5V ou 12V dos anos 70! Mini-bananas normalizadas que ainda hoje se fazem e posso comprar nas lojas de electrónica. Depois disso foi a desgraça, com conectores proprietários.
Estes agora ainda pior: não permitem paralelos (luzes, por exemplo) e os motores/sensores vêm com a ficha... se partires a ficha ou trincares o cabo, motor/sensor pró lixo. Muito sustentável e ecológico (e caro!)
As mini-bananas (e todos os outros sistemas que não o "9V") têm a desvantagem de não serem miniaturizáveis para Cidade e Espaço: com qualquer um desses sistemas não seria nada fácil fazer um 6480 com o tamanho que tem, por exemplo.
Até entendo a utilidade de ter vários pinos no conector: para alimentação, dados e (este talvez não tão indispensável) controlo directo analógico. Mas realmente ter o cabo permanentemente preso ao componente é muito má ideia! :notcool:
AVCampos Escreveu: 30 mai 2020, 12:56 As mini-bananas (e todos os outros sistemas que não o "9V") têm a desvantagem de não serem miniaturizáveis para Cidade e Espaço: com qualquer um desses sistemas não seria nada fácil fazer um 6480 com o tamanho que tem, por exemplo.
Tod a miniaturização terminou com o Power Functions. Daí para a frente tem sido só complicar e limitar a miniaturização. Compreende-se que não interesse à LEGO miniaturizar e sim agigantar: quanto maior o SET mais caro ele tende a ser (apenas numa perspectiva "de peso" porque ainda assim a miniaturização podia aumentar o interesse de certos sets como começam agora a descobrir com a iluminação, justamente a falha mais gritantemente absurda por tão óbvia do PU).
AVCampos Escreveu: 30 mai 2020, 12:56 Até entendo a utilidade de ter vários pinos no conector: para alimentação, dados e (este talvez não tão indispensável) controlo directo analógico. Mas realmente ter o cabo permanentemente preso ao componente é muito má ideia! :notcool:
O melhor argumento que vi tem a ver com sair mais barato por dispensar a ficha no motor/sensor e conseguir reduzir uns pózitos no tamanho do corpo. Acho um argumento pobre.
Quantos aos pinos....sendo o mesmo número de pinos do NXT/EV3 (6) porque raio não mantiveram a ficha RJ? Aproveitavam a incompatibilidade eléctrica para abandonar a RJ12 não-standard com o tab fora do sítio para adoptar a RJ11 universal ou mesmo a RJ45. Pra quê desenvolver uma ficha nova de raiz sem base em nenhum standard? Em tempos de impressão 3D à la carte, não é isto que vai impedir os chineses de copiarem.
Confesso que nem me lembrava dos connectors mais antigos mas depois de rever algumas imagens continuo a achar que os connectors dos 90s são mais "LEGO friendly" inclusive na forma como encaixavam (tal como uma peça normal).
