Descoberta supreendente sobre Godtfred Kirk Christiansen revelada no seu 100º aniversário
This article was written by Mads Klougart Jakobsen, Manager, Internal Communications, and first appeared on the employee-only LEGO web.
100 years ago, today, former LEGO® owner and managing director Godtfred Kirk Christiansen was born. His influence on the company and the success of the LEGO system in play is undeniable, but brand-new research done by our historians in LEGO Idea House shows that his influence on the LEGO brick and the company is even greater than we initially thought.
“For decades we have been unable to give a precise answer to the question of how the LEGO brick was developed, and who was the mastermind behind the design. We have been convinced that it was a lengthy development process carried out by a team of LEGO employees in the mid to late 1950s. Thanks to newly-discovered material, we have found out that Godtfred actually played a pivotal role in developing the LEGO brick that people all over the world love today,” explains Signe Wiese, Corporate Historian from LEGO Idea House.
Here is the never-before-told story of the development of the iconic LEGO brick:
It’s January 23, 1958. Three men are sitting in a LEGO office in Billund. The three men are Godtfred Kirk, his brother Karl Georg (presumably) and Axel Thomsen, head of LEGO sales office in Germany.
The latter explains that he’s getting complaints from his customers in Germany about the fact that models built with the company’s plastic building bricks are lacking stability and clutch power.
The problem is discussed at length, and several ideas and solutions are put forward. At some point, Godtfred finds a piece of paper with circles on, and starts to sketch the different ideas for a new brick design. That same day, Godtfred hands the sketch to Ove Nielsen, then head of the LEGO moulding shop. He is instructed to make a sample of the new brick design with two inner clutch tubes.
One of the first sketches of the design with two inner clutch tubes.
The following day, Godtfred brings his sketches and samples to the office of patent agency Hofman-Bang & Boutard in Copenhagen for them to get started on the work of applying for a patent. However, on his way home to Billund, he ponders over the idea of creating a new design for a brick with three inner clutch tubes instead of two. When he reaches Billund, he has come to the conclusion that three tubes will work better than two, because it will provide even better interlocking action.
He has Ove Nielsen create a new brick sample by cutting up and gluing together existing elements. This new three-tube design is then sent to the patent office with express courier. Only a few days later, on January 28, 1958 at precisely 1.58 pm, the LEGO Group files the application for a patent for a new type of building system. A system in which two or several interlocking plastic building elements can be put together in a great number of mutually different positions – or as it is more widely referred to: The patent of the LEGO brick.
“We’re now able to conclude that it took no more than five days to develop and patent the design of the LEGO brick, and we can also conclude that the mastermind behind this everlasting design was none other than Godtfred himself. I can’t find a more fitting way to celebrate his 100th birthday,” smiles Signe.
Fonte: LEGO Blog
Última edição por AVCampos em 09 jul 2020, 20:08, editado 1 vez no total.
Re: Descoberta supreendente sobre Godtfred Kirk Christiansen revelada no seu 100º aniversário
Este artigo foi escrito por Mads Klougart Jakobsen, gerente de comunicações internas e apareceu pela primeira vez na Web LEGO somente para funcionários.
Há 100 anos, hoje, nasceu o ex-proprietário e director-gerente da LEGO®, Godtfred Kirk Christiansen. A sua influência na empresa e o sucesso do sistema LEGO de brincadeira é inegável, mas investigações novinhas em folha feitas pelos nossos historiadores na LEGO Idea House mostram que a sua influência no tijolo LEGO e na empresa é ainda maior do que se pensava inicialmente.
“Durante décadas, não conseguimos dar uma resposta precisa à questão de como o tijolo LEGO foi desenvolvido e quem era o cérebro por trás do design. Estávamos convencidos de que foi um longo processo de desenvolvimento realizado por uma equipa de funcionários da LEGO em meados ao final da década de 1950. Graças a material recém-descoberto, descobrimos que Godtfred na realidade desempenhou um papel fundamental no desenvolvimento do tijolo LEGO que hoje em dia as pessoas adoram”, explica Signe Wiese, Historiadora Corporativa da LEGO Idea House.
Aqui está a história nunca antes contada do desenvolvimento do icónico tijolo LEGO:
É 23 de Janeiro de 1958. Três homens estão sentados num escritório da LEGO em Billund. Os três homens são Godtfred Kirk, o seu irmão Karl Georg (presumivelmente) e Axel Thomsen, chefe do escritório de vendas da LEGO na Alemanha.
O último explica que ele está a receber reclamações dos seus clientes na Alemanha sobre o facto de que aos modelos construídos com os tijolos de plástico da empresa falta estabilidade e força de encaixe.
O problema é discutido detalhadamente e várias ideias e soluções são apresentadas. Em determinado momento, Godtfred encontra um pedaço de papel com círculos e começa a esboçar as diferentes ideias para um novo design tijolos. Nesse mesmo dia, Godtfred entrega o desenho a Ove Nielsen, então chefe da oficina de moldes LEGO. Ele é instruído a fazer uma amostra do novo design de tijolo com dois tubos de encaixe internos.
Um dos primeiros esboços do design com dois tubos de encaixe internos.
No dia seguinte, Godtfred leva os seus esboços e amostras ao escritório da agência de patentes Hofman-Bang & Boutard, em Copenhaga, para que eles iniciem o trabalho de pedido de patente. No entanto, a caminho da sua casa em Billund, ele pensa na ideia de criar um novo design para um tijolo com três tubos de encaixe internos em vez de dois. Quando ele chega a Billund, ele chegou à conclusão de que três tubos funcionarão melhor que dois, porque proporcionará uma acção de interligação ainda melhor.
Ele faz com que Ove Nielsen crie uma nova amostra de tijolos cortando e colando elementos existentes. Esse novo design de três tubos é enviado ao escritório de patentes por correio expresso. Apenas alguns dias depois, em 28 de Janeiro de 1958, exactamente às 13:58, o Grupo LEGO regista o pedido de patente para um novo tipo de sistema de construção. Um sistema no qual dois ou vários elementos interligáveis de construção de plástico podem ser montados num grande número de posições mutuamente diferentes - ou como é mais amplamente referido: A patente do tijolo LEGO.
"Agora, podemos concluir que não demorou mais de cinco dias para desenvolver e patentear o design do tijolo LEGO, e também podemos concluir que o cérebro por trás desse design eterno não foi outro senão o próprio Godtfred. Não consigo encontrar uma maneira mais adequada de comemorar o seu centésimo aniversário ", sorri Signe.
Fonte: LEGO Blog
Continua a não esclarecer a minha questão mais profunda!...
Como e porque raio foi escolhida a proporção maravilha do brick elementar (5x5x6) ???
Na altura as peças eram todas muito básicas e não se antevia nada do tipo de peças que surgiram muitos anos mais tarde e continuam a surgir, e que tiram excelente proveito das propriedadades dessa proporção. Refiro-me naturalmente a a brackets, washing machines e outros bricks com studs dos lados, que por sua vez são a base de muitas técnicas SNOT.
Custa-me imenso a crer que isto tenha sido pensado à priori...
Portanto será tudo uma tremenda e feliz coincidência!?? Também custa um bocado a engolir!... ::) :dontcare:
A explicação verdadeira é que, tal como na Proporção de Ouro da regra de Fibonnaci ou na história "Contacto" de Carl Sagan em que PI aparece escondido dentro da própria sequência de algarismos que o exprimem, O Supremo Construtor na Sua Suprema Sabedoria embutiu essas proporções no Supremo MOC aquando do Momento da Grande Construção.
Mas como nem todos estão preparados para tamanho conhecimento arranjou-se uma história mais prosaica que infelizmente tem as suas falhas.
Tudo isto é verdade porque rima.
A proporção de ouro também foi o que veio à cabeça enquanto escrevia o meu post!... ;D
Conchas Escreveu: 10 jul 2020, 02:15 Como e porque raio foi escolhida a proporção maravilha do brick elementar (5x5x6) ???
Ah, não sou o único a coçar a cabeça à conta disso! Mas as técnicas e whatnot que foram desenvolvidas não são mais que workarounds para as proporções estranhas: o SNOT seria brutalmente mais fácil se um brick fosse 1x1x1. Aliás, foi quase de certeza por causa disso que fizeram o Modulex em 1x1x1 e o Technic migrou para o studless (que também é 1x1x1).
