Informação sobre novas alterações na palete de cores
Novidades do Design Lab.
Mais alterações na palete de cores!
Desagradou-me particularmente, que o Trans-Black(111) esteja planeado ser descontinuado a partir dos novos produtos para 2011. :notcool:
"Changes of color 131 and 148
We are constantly trying to make our processes and visual color expressions more efficient and effective, and in this work we have identified a need for improvement with our colors 131 Silver and 148 Dark Metal.
Both colors are only used on specific LEGO elements, and the colors have been updated several times through the years.
In this case we looked for an updated visual design expression and at the same time the possibility to reduce cost, as we never were 100% satisfied.
The improvement in the visual expression is  only slightly changed, but we have decreased the cost in the color process.
We wish to transit from the old, to the new colors as smooth as possible – as the difference in visual expression is only slightly improved.
But as we never uses these colors in big surfaces, and only in details or effects, we think that the transit would course minimal fuzz.
New color – 111 goes out
In our development of new themes and products, we also find it very useful to implement new colors as well as elements. On the same time, we keep a tight governance over our LEGO color palette, and manage a specific total of old contra new colors in the palette. In this case we decided that the coming color (name and number not official yet), should replace the existing color 111.
This transit will not take place until in the 2011 products."
Edit:
Esta informação foi posteriormente dada como tendo sido um mal entendido!
Ler mais abaixo.
Última edição por Conchas em 08 nov 2009, 09:12, editado 1 vez no total.
Re: Informação sobre novas alterações na palete de cores
Se há coisa que me irrita é estas trocas de cores.  :notcool:
Muito manhoso ficar sem "vidros fumados"  :notcool:
Mas a LEGO tem recentemente usado tantas vezes o "smoke" em aplicações onde dantes usava o transparente normal... :-\ É estranho terem decidido acabar com ele!
Pelos vistos, a LEGO vai ser só para "non-smokers"...  >:D
Mas agora a sério, também acho uma péssima ideia.  :notcool:
Neste momento não sei se a nova cor, não será um reajuste da anterior.
Suspeitas... teremos de esperar para ver. ???
A informação anteriormente veiculada, foi agora dada como tendo sido um mal entendido!
O Design Lab procura continuamente tornar a palette de cores o mais consistente e eficiente possível.
Contudo a mensagem anterior não passam de ideias ainda por decididir.
Pessoalmente admito que a mudança nas cores pearl seja mais ou menos pacífica, mas quanto ao Trans-black não será assim certamente.
Questiono-me até que ponto, esta não terá sido uma "manobra" para auscultar a receptividade dos fãs em que rápidamente se verificou que não seria uma alteração do agrado dos mesmos.
