@ here
Stare at [Luke's] LEGO router case; STARE AT IT! The router is nothing special, a WRT54GL that is fun to hack. We’ve seen it used as a robot, turned into a war driving box, and obviously this is where dd-wrt custom firmware started.
[Luke] designed the case in MLCAD and found a seller for the parts which came in just over $50. We think it’s much better looking than the stock case an if you used that for a different project, this is a way to replace it. We’ve embedded [Luke's] assembly video after the break. If you like this case, take a look at his LEGO PC case as well.
[youtube]http://www.youtube.com/watch?v=GE7BV80i ... r_embedded[/youtube]
