SR 3D Builder 0.5.6.11 Released
xSergio74
Mensagem por xSergio74 »
Hi,
I have just released an updated version of the application.
Again nothing really new. Just working hard to fix many problems of previous releases.
This new version should be considerably more stable even if you will find some bugs for sure.
Please have a look to my application http://staff.polito.it/sergio.reano/ history page for a brief description of changes/fixes.
enjoy building and as always, feedback
Here is another small video with a great new feature for flex
Sergio
Última edição por xSergio74 em 17 mai 2011, 12:36, editado 1 vez no total.
xSergio74
Re: SR 3D Builder 0.5.6.11 Released
Hi,
another quick fix has just been released to fix some latest reported bugs.
Download from my application download page
Sergio
I tried now the latest version and it starts. :fixe:
However, when it starts, it reports that my graphics card (GeForce4 Ti4200 with DirectX 9.0c) doesn't support antialiasing multisample features. I click OK, and the application gives me this exception:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at d.d()
   at f.bq(Object A_0, EventArgs A_1)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SR3DBuilder
    Assembly Version: 0.5.6.11
    Win32 Version: 0.5.6.11
    CodeBase: file:///C:/Program%20Files/Graphics/SR%203D%20Builder/SR3DBuilder.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.DirectX.Direct3D
    Assembly Version: 1.0.2902.0
    Win32 Version: 9.05.132.0000
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll
Microsoft.DirectX
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
Microsoft.DirectX.Direct3DX
    Assembly Version: 1.0.2911.0
    Win32 Version: 9.12.589.0000
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3DX/1.0.2911.0__31bf3856ad364e35/Microsoft.DirectX.Direct3DX.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I click "Continue" and I get the app's main screen, with a blank workspace (no parts palettes). If I try to import or load an LDR file, I get another exception:
System.NullReferenceException: Object reference not set to an instance of an object.
   at f.bl(Object A_0, EventArgs A_1)
   at f.o(Object A_0, EventArgs A_1)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
mscorlib
SR3DBuilder
System
System.Drawing
System.Xml
Microsoft.DirectX
ImageCombo
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/Graphics/SR%203D%20Builder/ImageCombo.DLL
enabled.
For example:
<configuration>
</configuration>
Could this all be because my graphics card is old? On the thread about a previous version, you said it was expectable that it wouldn't work well with SR3DB.
OMG! I feel so happy! Now I know I'm not the only one still stuck with a TI4200  :P
xSergio74
Hi,
try the following:
- ensure the application is NOT running
- open Lego3D.ini in your SR3DBuilder application folder (usually c:\Program Files\SR3DBuilder) with a text editor
- search and replace the Multisample entry with the following:
MultiSample=0 - None (Fastest) (copy and paste the line to ensure typing)
- Start the application
- FEEDBACK
Sergio
I changed the INI file, and now SR3DB doesn't show any error message when I start it. After a few seconds, it gives this exception:
  at d.d()
mscorlib
SR3DBuilder
System
System.Drawing
System.Xml
Microsoft.DirectX
enabled.
For example:
<configuration>
</configuration>
It appears to be the same exception as before. :(
