LDD Manager
LDD Manager
Mais uma ferramenta para o LDD.
Esta aplicação permite analisar um modelo LDD e enviar as peças deste para o Bricklink.
Via Eurobricks: http://www.eurobricks.com/forum/index.p ... t&p=740445
UPDATE August 2012: The latest version is now 1.01 with support for LDD 4.2.5. If you have a previous version, you should download the new version. NOTE, installing a new version will remove your previously imported LDD-files, but hopefully it's not too much work to import them again.
