Hi everybody !!
As promised, even if a week later, here is another program update.
Before continue: if someone downloaded the program on September 2, 2013 before this announce, probably got a wrong version. If this is the case, download again from now.
Most important new is support for Mindstorm EV3 parts and a bounce of bug fixes.
As often, here is a presentation video:
Follow a list of changes:
Fixed
- Flexible parts with fixed length can freeze the application
- Hinge Solver now works with 32494.dat parts: just place on their final position and select both of them with the Hinge Solver tool
- Hinge Solver now works with Universal Joint 3L in all cases
- Mirror building now works again
- Using Half pin with stud part can occasionally lead to an error
- Some gears interferences in particular compact mechanisms
Added
- Support for Mindstorm EV3 parts (Thanks to Philo for this!!)
- Latest Official and Unofficial lDraw parts update
SR 3D Builder version 0.8.11.5
xSergio74
- Full Member
- JMCampos
Re: SR 3D Builder version 0.8.11.5
Hi Sergio,
After installing, when I try to run the program I get the following error message:
... and the program will not terminate unless I 'kill' it via Task Manager.
Is there a simple way for me to correct this issue? Thanks a lot!
Thebicyclestory
xSergio74
- Full Member
[quote="Thebicyclestory"]
I get that same error message too.
[/quote][quote="JMCampos"]
Hi Sergio,
Hi,
if this is the first time you try installing my program and you have a previous lDraw/MLCad installation on your PC then probably that is the problem.
To solve the issue:
- temporary rename any c:\ldraw folder to something else
- reinstall SR3DBuilder. During installation you will be asked for a folder where install part library to: default is c:\ldraw, but you can choose any different folder. If you do not use MLCad then leave default value; if you use MLCad, I recommend you to choose a different folder. Remember your choice.
- let part library extraction complete
- Start SR3DBuilder. If your choice is different from default, you will be asked for the part library folder name
- Let part list inventory to be build (a few seconds or a pair of minute depending on your HW)
- No errors should appear now...
Hope this work.
Sergio
Hi Sergio,
Hi,
To solve the issue:
Hope this work.
Sergio
